FIRST Robotics Competition Discussions
Help - Fatal Error!! Required NiPathsDir property METAUNINSTALLERDIR is undefined
Put a new hard drive in a computer and am installing labview 8.5.1 again. I get the error - Fatal Error !! Required NiPathsDir property METAUNINSTALLERDIR is undefined.
I found one page of instructions on fixing this and it did not help.
Any help would be appreciated.
thanks..
(4,843 Views)
What are you using for your install disks?  Which operating system?  This year's FIRST competition is using LabVIEW 8.6, not 8.5.1, so either you've typed the wrong version or you have the wrong disks.  If you're not installing this as part of the FRC control system, then you're posting in the wrong forum, and you should try the LabVIEW forum at http://forums.ni.com.
(2,809 Views)
