FIRST Robotics Competition Discussions
Incorporating Dashboard into cRIO Projects
I have been over the tutorials and all the provided ones on FRC Mastery.
I am still confused on how to incorporate a Dashboard Project with a cRIO project.
A few goals i want to accomplish are: Sending camera signal directly to Dashboard and Custom Dashboard that has the stuff I want (display all of my PWM outputs in Digit form, organize it differently, ect.).
I understood how to change the outputs of the PWM to indicators on my own using the Dashboard Main code.
But how do I make that Dashboard be the one that opens at competition and all?
And is that fully incorporated enough as far as coding needed in the default cRIO Project code?
Davis Catherman
(4,402 Views)
Hey Davis,
I'm not quite sure I understand what it is you are trying to do... the Dashboard Project and cRIO Projects are two different things; they are not incorporated into each other.  You can select which type of project to create on the Getting Started Window.
Barron
Barron
Applications Engineering
(2,869 Views)
