FIRST Robotics Competition Discussions
Joystick trigger to digital output example?
We are trying to simply wire a joystick trigger to turn on a digital output when it is pressed. Has anyone tried this? All the digital output examples on the net are not for this specific situation and I can't get any of them to work properly.
(4,357 Views)
You should be able to use the JoystickGet.vi in order to pull out a boolean value from your button on your Joystick and feed it directly into a DigitalOutputSetValue.vi. You can see an example of this in this VI snippet.
Miles G.
Emerson Test & Measurement Group
Senior System Support Engineer
(3,473 Views)
