FIRST Robotics Competition Discussions
LabVIEW Installation issues -- Real Time Module
I have been trying to install the FRC edition of LabVIEW on my laptop. When the installer reaches LabVIEW real time module, windows setup crashes with no error message being generated other than "setup.exe has stopped working". In the post-install, I am told that a version of "NI-VISA" has been detected on my system that is not supported. I cannot find a trace of any such program, in either my program list, or even the registry. I normally consider myself fairly computer literate, but this is absolutely stumping me. I've tried installing as an Admin, fresh re-installs, and various compatibility settings, but nothing seems to work. Any suggestions?
My system specs:
HP dv6
Windows 7 Home Premium, 64 bit
4GB ram
AMD Phenom II N930 2GHZ quad core processor
~350GB of free hard drive space
(4,379 Views)
Do you have other software from National Instruments installed?  If so, you could try uninstalling it first and then installing LabVIEW for FRC.
If not, do you have LEGO MINDSTORMS software installed?  I'm not sure if you should run into a compatibility issue with it, but at least at one time in the past NI-VISA was installed as part of it.
Geoff Schmit
Huskie Robotics, FIRST Team 3061 Lead Mentor
http://team3061.org/
@team3061
(3,189 Views)
