Tutorial 6—Creating a Custom Dashboard
Use the FRC dashboard project on the host computer to create a custom dashboard that allows you to view data that the roboRIO returns. This project can display images and I/O values that the roboRIO sends to the host computer.
Complete the following steps to create an FRC dashboard project.
The FRC dashboard project looks similar to the following figure:
Whereas the FRC robot project contains two targets, the FRC dashboard project contains only the My Computer target. You run the VIs in the FRC dashboard project only on a host computer. You do not deploy these VIs to the roboRIO.
The My Computer target contains a Dashboard Main top-level VI and a Support folder. The Support folder contains VIs that the Dashboard Main VI calls. You might not need to modify any of the VIs in this folder.
The Dashboard Main VI is the master VI in the FRC dashboard project. You can use this VI on the host computer to view image data that the camera connected to the roboRIO acquires.
You also can use the Dashboard Main VI to read information about the robot, such as motor drive values, battery level, and any other data you want to send from the robot. In the Project Explorer window, double-click the Dashboard Main.vi item to open the Dashboard Main VI. By default, the front panel displays the following information:
Select Window»Show Block Diagram or press the <Ctrl–E> keys to view the block diagram of the Dashboard Main VI. The block diagram contains three While Loops you may choose to edit.
In Loop 1, the Dashboard Main VI receives data about the robot from the driver station. By default, the Dashboard Main VI connects to the driver station through TCP and UDP connections and receives data about the robot. This data includes Status Info, Control Info, Robot Metrics, and Power and Errors information that can be used by the dashboard. This loop is also used to read Network Table variables from the robot. Notice that "RobotDrive Motors", the string constant value wired to the Name input of the NT Read VI, exactly matches that used for the NT Write VI in the Teleop VI of the robot code.
In Loop 2, the Dashboard Main VI retrieves specific images on the host computer from the image data that either the roboRIO sends, or that is sent directly via the robot radio. The Dashboard Main VI creates a JPEG image, continuously replaces this image with the most recent image data from the camera, and displays the image in the Image indicator on the front panel. By default, camera image acquisition is off - you must choose your connected camera type from the front panel menu.
Loop 2.5 adds the ability to show images from a second camera.
Below Loop 2.5 is code that typically does not need to be modified. There are terminals for Test Mode, Camera Settings, the Basic tab, etc. There are also additional loops whose purposes are described on the diagram itself.
You can use the WPI Robotics Library VIs and other LabVIEW VIs to modify the types of data the Dashboard Main VI displays.
Modifying the FRC Dashboard Project
The Dashboard Main VI in the FRC Dashboard Project displays information about the robot. You can use the Dashboard Main VI to receive live feedback from the robot. The Dashboard Main VI also displays user-defined data and the input and output values from the roboRIO, the robot, and the driver station. Refer to Tutorial 7—Integrating Examples into Robot Code for information about modifying the dashboard project.
Rebuilding the FRC Dashboard Project
After you customize the FRC Dashboard Project, you must rebuild the project so that the Driver Station launches the most recent version of the project.
Complete the following steps to rebuild the project and specify which project the Driver Station launches automatically.
