FIRST Robotics Competition Discussions
Labview Enhanced I/O Palette / FRC Driver Station / Cypress PSoC 3
Has anyone been successful in implementing the Cypress PSoC 3 board with the FRC Driver Station? There appears to be a severe lack of information on how to implement these Labview WPI function blocks.  I am trying to read digital input switches and have not found any information on how to setup the hardware/software to complete this task.
(6,010 Views)
Have you configured your Driver Station for the I/O configuration that you are trying to use?
There is some introductory information in this two documents:
http://decibel.ni.com/content/docs/DOC-8853
http://decibel.ni.com/content/docs/DOC-8861
Are you having problems using the VIs and understanding how they work or is this an issue of setting it up with the Driver Station in order to utilize the I/O?  If you can be a little bit more specific we can try to get you the information that you need.
I hope this helps!
Thanks!
Bob H
NI FIRST Support
Thanks!
Bob H
(2,844 Views)
