FIRST Robotics Competition Discussions
Labview execution error code: Exception: Unknown (0xC06D007E) at EIP=0x771EC54F
After installing the 2017 Labview code and requred updates for FRC, I get the error code below.  What does it mean, and how do I correct?
(5,479 Views)
I'm encountering this same kind of issue.
Exception: Unknown (0xC06D007E) at EIP=0x773C5B68
Any idea how to fix this?
Thanks in advance!
(5,342 Views)
We encountered something like this during the Kickoff workshop. The student didn't remove all previous version of LabVIEW and was installing from the DVD.
We removed all previous LabVIEW version and used the downloaded files (because I had them on a USB drive and this would install faster then the DVD). The uninstall took forever but it worked.
Do either of you know if LabVIEW would run before you installed the FRC 2017 Update Suite?
Let me know if this helps.
Ryan
(5,321 Views)
