FIRST Robotics Competition Discussions
Labview installation
We are attempting to install 2013 labview on the 2009 classmate. It gives an error message "Targetdir is undefined". Any ideas what we need to do?
(4,572 Views)
You see this error message while running the installer? Did you install the components on the DVD from the Kit of Parts first (or use the new image for the classmate)? Are you installing in a non-default directory?
Kevin Fort
Principal Software Engineer
NI
(3,754 Views)
Accepted by topic author andivwh
Yes we were running the installer and were using a flashdrive that we had copied the program onto. We were trying to use the classmate from a previous year KOP. I am not sure about your last question. We were trying to get the cRio reimaged for this year's season and our main programming laptop would not image it. So we thought we would use the classmate. We were able, later in the evening, to get it imaged and are up and ruinning now. Thank you for your response.
(3,754 Views)
