FIRST Robotics Competition Discussions
Limit switch stop all motors !
I have another, for me, when the limit switch is activated, all motors stop. I follow the tutorial in http://www.frcmastery.com/labview-for-frc/2011-frc-steps-to-robot-success/step-4 -add-a-digital-inpu... but i added only déclarations into "Begin.vi" and into "Finish.vi" and nothing in "Teleop.vi". Does anyone have any suggestion ?
Team 3969.
(6,012 Views)
From the link you provided I suspect you need this step:
"Modify the Teleop SubVI to replace the momentary joystick button with a limit switch"
What is the desired functionality for your robot? To Stop all motors when the limit switch is activated? In that case you will need to put a case structure in teleop which sets the speed of all your motors to 0 when the limit switch is activated.
Kevin Fort
Principal Software Engineer
NI
(3,710 Views)
No, my problem is even I don't add to labview any program the limit switch stop all motors !
I want to stop only one motor (desired) not all.
(3,710 Views)
I think in ithat case you will just need to add a case structure which reads the state of the limit switch and sets that desired motor to a speed of 0. If you need help with the motor control pallette take a look at the Basic Motor Control Tutorial on the documents page of this community.
Kevin Fort
NI
(3,710 Views)
We found the problem that was with the wiring, now it works perfectly.
thank you.
(3,710 Views)
