FIRST Robotics Competition Discussions
Major Problems With Crio! NEED HELP FOR OUR TEAM!!!!!!!!!!!!!!!!!!!!!
Our team 2739 is getting fed-up with the Crio. The thing is not WORKING!!
List of problems that we are having:
Dashboard shows no Crio image, though we have succesfully imaged the Crio.
Crio Status light flashes four SHORT flashes then pauses for approx 2 seconds, then repeats.
Occasionaly, the "Communications" LED turns on for a short time, showing voltage for the battery, then turns off again.
We have all updates that are for the Netbook(classmate), Labview, Crio, Gaming Adapter, and Router.
We can deploy the code no-problem, but then it pukes and dies...
PLEASE help, our team has searched and searched, and we need suggestions PLEASE, all posts on this website have not had any fixes suggested, rather most people that try to help wind up posting USELESS(!) questions that are only for if you're team has just some random setting wrong or something similar.
We have tried almost everything, and our mentors have done almost all they can to help.
Also, the code we are deploying is Labview's own 2010 code without any modifications whatsoever.
You can contact our mentor Mr. Steve with any questions or answers at sejeffries@gmail.com
(4,349 Views)
Funnily enough, this sounds like pretty much the exact same problem I just posted for my team! I would love to tell you how to fix it, but I don't know myself.
(3,151 Views)
DatapawWolf,
All these issues you're seeing. Do they happen when you using a direct connection to the cRIO (crossover cable) or when you are going through the full network (Router and Gaming Adaptor)?
Ben Sisney
FlexRIO V&V Engineer
(3,151 Views)
