FIRST Robotics Competition Discussions
Mecanum drvie not working (error 44061)
I'm trying to help a team using the mecanum drive. They're getting an error 44061 that the code in robot main is taking to long. There teleop.vi only takes joystick inputs and calls the mecanum drive vi. There begin.vi seems to set up 4 motors correctly and those are the only changes they've made.
What could  be causeing the error? What can be done to fix it?
Any help would be great!
"Lockheed" Joe
Testing Blog"
(4,924 Views)
I think im getting same error but it is not affecting anything.
Does the robot loose connectect about every 15 seconds or something?
If so make sure you open, feed, close the watchdog in the begin, autonomous, teleop, and close vi.
Davis Catherman
(3,137 Views)
Thanks, there robot wasn't moving. However, they were getting that error but it due to something else (the mis-named a get reference in the teleop vi)
It's working now.
"Lockheed" Joe
Testing Blog"
(3,137 Views)
