FIRST Robotics Competition Discussions
Need help downloading Labview
Hey,
So when I downloaded Labview 3013 and everything fine with the DVD from the kit of parts. Then when I got to unzipping the update suite and running the setup.exe, this happenedhardware_req.png
Need Some Advice on what to do.
Thanks Kevin
(5,267 Views)
Hi Kevin,
I'm confused because you said you were downloading the FRC Update suite but the screenshot you sent shows an install of LabVIEW. Are you downloading the Update suite from here?:
https://decibel.ni.com/content/docs/DOC-34731
The popup you are seeing is asking you to install drivers which you can install support for if you have the disk or driver downloads or decline support if you want to go ahead and install them later.
When I install the Update Suite, the installer says FRC 2014 Update Suite at the top.
(4,245 Views)
Well I did download the update suite from here https://decibel.ni.com/content/docs/DOC-34731, but I couldn't open the setup. So I asked one of my mentors and he copied his update suite onto a flashdrive and I copied it from there. I thought it would work, but after 99% the same pop up came up again.
(4,245 Views)
Did you unzip the download file before trying to run Setup.exe?
(4,245 Views)
