FIRST Robotics Competition Discussions
Out of memory / corrupt startup file
After reformatting the roborio and installing the Talon support through Phoenix tuner, a download of a build for startup works file. However, after a couple of these download to run on startup, an out of memory error is thrown when trying to download. Also when running labview interactively, a corrupt startup file warning is thrown. I can ignore and run anyway and it seems to work ok.
Any suggestion on how to clear the error without reformatting the roborio before downloading builds for startup?
(2,967 Views)
Hey brhea,
Good next step is to safe mode reimage, then load just load your code. If that still gives an error, then it is likely something in the code. If you don't get the error until after adding the Pheonix stuff then you will want to talk to CTRE about this issue.
Regards
Austin
(2,935 Views)
