FIRST Robotics Competition Discussions
Please Help, code / robot / driver station / joystick Problem
I have recieved confirmation that I have successfully re-imaged the cRIO.
I have installed the Labview, Driver Station, and Utillities updates today then ran all the tests.
I then ran the provided Servo Example code in the FRC examples link on the Labview Welcome screen and the servo worked perfectly.
Then I attempted my own code for motors (didn't work), then the provided Arcade Example (didn't work), and then the provided Motor Example code which did not require a joystick (didn't work).
The Code:
Each of the codes were set to the correct team IP.
Not sure if it was working right (but 2 of them were provided).
The on code configurations were correct,
The Robot:
The control wire was correctly inserted in the Victor and PWM 1 on the Digital Side Car.
The Victor had power.
I even tried 2 different Victors.
The Victor light keeps flashing orange.
Everything else seems to be communicating and wired correctly.
The Driver Station / Joystick:
Registering the joystick as beeing in USB 1.
No errors in the error log.
Getting code and enabling correctly.
Team number is displaying correctly.
Davis Catherman
(5,340 Views)
uhh, well yesterday it just decided to work. I don't know why but nor do I care as long as it never happens again...
Davis Catherman
(3,534 Views)
