FIRST Robotics Competition Discussions
Problem with connecting to cRIO
I have set the ip adress on the laptop according to the instruction maunual, but when I try to hook up the ethernet cable, my computer displays "Unidentified Network" under the local area connection.
Message 1 of 23
(15,130 Views)
I don't think that is entirely unexpected that the network shows up as an Unidentified Network. Are you able to see the cRIO in Measurement and Automation Explorer? Are you able to detect and image the cRIO using the imaging tool?
Kevin Fort
Principal Software Engineer
NI
Message 2 of 23
(5,565 Views)
I was not able to detect it using the imaging tool, and I haven't found it in MAX
Message 3 of 23
(5,565 Views)
Sounds like the IP address or subnet on the cRIO itself is not set up correctly. If you do an IP Reset and boot into safe mode while the cRIO is directly connected with a crossover cable to your computer (which should be set to automatically acquire an IP Address) are you able to see the controller in MAX? If so you should set the IP and subnet to their proper values and then take the controller out of safe mode and set your computer back to its static IP.
Kevin Fort
NI
Message 4 of 23
(5,565 Views)
I have booted it up in safemode, with the ip reset, and in MAX I see the following under "devices and interfaces": Network devices [there's nothing in it] PXI Syestem (Unidentified), and under "Serial & Parallel" there is: LPT1, which says "MAX could not open a VISA session to this static device. The device was not returned from VISA when finding recources, but MAX was able to parse the recource name."
Message 5 of 23
(5,565 Views)
The cRIO should show up under remote systems in MAX. Another method to find the IP Address of the cRIO is to use the console out switch and connect the serial port on the cRIO using a null modem serial cable to your computers serial port.  More information on doing this is available here:http://digital.ni.com/public.nsf/allkb/354A5124E6A667988625701B004A77CD . Are you using an FRC 1 or 2?
Kevin Fort
NI
Message 6 of 23
(5,565 Views)
There is nothing under remote systems, and I can't seem to find a serial port on the notebook thing that we have. (2gp pc)
Message 7 of 23
(5,565 Views)
Plus I don't think we have that cable right now...
Message 8 of 23
(5,565 Views)
Some other things to try would be to disable or enable your wireless card or other NICs (whatever the opposite of what is now). Additionally I would try connected to the cRIO through a hub or switch instead of directly to your PC.
Kevin Fort
NI
Message 9 of 23
(5,565 Views)
Now, I booted it up with all of the dip switches set to off, the big rsl light is blinking.
Message 10 of 23
(5,565 Views)
