FIRST Robotics Competition Discussions
Problem with using cRIO joystick via WIFI
Hello!
We managed to make our robot work with the ethernet cable and control the motor with the Logitech 3 Attack. So far, all is good. Right now , we are trying to use the joystick plugged on the laptop via wifi (router dlink on the robot). It would be a huge help if someone could point out a reference or a tutorial because we tried a lot of stuff and sadly got nowhere...
Thank you!
(3,871 Views)
Hey RiceKernel,
Are you running the driver station on the laptop with the joysticks plugged in? Do all the diagnostic and status pages of the driver station look the same as when connected with an ethernet cable?
Kevin Fort
Principal Software Engineer
NI
(2,931 Views)
