FIRST Robotics Competition Discussions
Question about cRio FRC II and c modules
I am running v52 of the cRio image from 2014. When I tried to plug-in a more precise (instrumentation) grade analog module into the chassis it turned the slot icon red. Is the cRio 4 slot only usable by the 3 FRC approved modules? If I buy additional labview licenses would that enable the use of other modules in teh chassis?
Ken
(3,211 Views)
Hi Ken,
You might try downloading the full driver set. It has been a while since I have come across that but I think it is due to a missing driver.
Which analog module did you try? If I have it I will give it a try on this end too.
Let me know if that helped.
Ryan
(3,166 Views)
