FIRST Robotics Competition Discussions
Robot hasn't moved yet error Warning code 44002 occured at Ping Results: link-GOOD, DS radio(.4)-bad, robot radio (.1)-bad cRIO (.2)-bad FMS bad driver station Please interrupt, Thanks!
I'm using labview with one joystick. Robot hasn't moved yet error Warning code 44002 occured at Ping Results: link-GOOD, DS radio(.4)-bad, robot radio (.1)-bad cRIO (.2)-bad FMS bad driver station Please interrupt, Thanks!
(5,838 Views)
Hi BullBot,
Based on the FIRST Robotics Competition Error Codes list, which can be found at the link below, you may need to reimage your cRIO with the cRIO Imaging Tool.
http://zone.ni.com/reference/en-XX/help/372635F-01/frc/frc_error_codes/
The instructions for using the cRIO Imaging Tool can be found on page 11 of the FRC Getting Started Guide, which can be found at the link below.
FRC Getting Started with the 2013 FRC Control System
http://www.usfirst.org/sites/default/files/uploadedFiles/Robotics_Programs/FRC/Game_and_Season__Info...
-Tunde
Tunde S.
(3,824 Views)
