FIRST Robotics Competition Discussions
Router problems.
We accidentaly fried our d-link radio, I was wondering if we could use a "Linksys E3000" router instead, I haven't been able to make it work, but I was hoping someone had a suggesion.
(5,271 Views)
You should be able to set it up with other routers (not for competition use)- the configuration will be different depending on the router. You will probably need to set it up in bridge mode (if thats not an option in the default firmware you can consider installing dd-wrt)
Kevin Fort
Principal Software Engineer
NI
(3,953 Views)
As defined by [R55].
(3,953 Views)
