FIRST Robotics Competition Discussions
System watchdog disables when going from enabled to disabled: OK? How to fix?
We consistantly get a watchdog error report on the driverstation that shows one more system watchdog trip every time we go from enabled to disabled. It doesn't cause anything else noticeable on the robot. This post on Chief Delphi says that this is probably ok, but still, is this really an issue and/or is there something that we can do to fix it? Thanks!
(5,581 Views)
Hi LabVIEWEnthusiast,
It's been a while since you first posted this; are you still running into this issue?
Andy H.
(3,000 Views)
