FIRST Robotics Competition Discussions
Totally newbie rookie team
Can someone help with an example of how to integrate the example compressor code into the main robot code?   We are a completely rookie/newbie team and need help with labview big time...  That and we can't figure out how to map like say turning on a motor to move an actuator to a joystick button.
Dan
(5,523 Views)
If you are just getting started http://www.frcmastery.com/ is where I would go to learn about labview and the FRC framework.
(3,716 Views)
Howdy Dan!
There is a tutorial available on the LabVIEW FRC Getting Started Window which describes how to integrate example code into the robot code.  Also, there are lots of examples included in the example finder specific to FRC which should help you getting started with most basic operations.
Barron
Barron
Applications Engineering
(3,716 Views)
