FIRST Robotics Competition Discussions
Trouble downloading
I'm new to LabView.  While trying to open the FTC templates for teleop and autonomous, I get messages telling me to find the following:
    "FTC Move Servos, vi"
    "Pad Selector Input, ctl"
    "Merlot Radido Button, ctl" and
    "FTCMove Motors"
I don't know where they are or where to look for them.  When I do a search at any level, the search returns a negative result.  Can anyone help?
(4,152 Views)
Robot Rebels,
Are you using LabVIEW 2009, LEGO® MINDSTORMS NXT Module 2009, and the FTC 2010 Toolkit?  When did you download and install the later two items (NXT and FTC software)?  Where did you get these templates?  I'm guessing you might have downloaded them from the Robotics Academy.  Please be aware those are not the templates that should be used for the 2010 season.  The autonomous and teleop templates for the FTC 2010 season install with the FTC installer and can be found in the following location on disk.
C:\Program Files\National Instruments\LabVIEW 2009\examples\FTC Toolkit\Templates
There should also be a shortcut to the FTC examples on your desktop after you have finished installing the FTC Toolkit.
I hope this helps,
Mark
LabVIEW R&D
Mark
NI App Software R&D
(2,810 Views)
