FIRST Robotics Competition Discussions
Two Motors on One Jag?
Read the manual!
Read rule [R46]. Key in on the words "one and only one"
This applies Jags and spikes.
Omar
Message 11 of 12
(1,137 Views)
If you mean minimal current (ie minimal torque) instead of minimal voltage (ie minimal speed), a spike will work. However, a spike only outputs +/- 12v, you have no control over the voltage, so if you really meant minimal voltage it won't work in your application. You also need to make sure that the motor you are powering with a spike is legal per R50.
Message 12 of 12
(1,137 Views)
