FIRST Robotics Competition Discussions
Two USB Cameras on RoboRio?
We are trying to put 2 usb cameras on our robot and are having issues.  We plug them both in as usb on the RR and can only select/see 1 on the drive rotation.
Ideally we’d like to use a button to switch from one to the other, or have them both display on the driver station.
Any help woudl be appreciated.  First comp this Saturday!
We are using LabView...not a lot of java expertise.
Thanks in advance.
Greg
(4,137 Views)
I haven't worked with RoboRio but might be able to give you a hand.
LabVIEW establishes a communication between a camera using IMAQdx driver.
I don't know how are you developing your application but in general,
you can call multiple "IMAQdx Open Camera.vi" in parallel and have communications.
Certified LabVIEW Developer
GCentral
(4,118 Views)
