FIRST Robotics Competition Discussions
Update question and cRIO IP Address Issues
What is the status of the "status" light on the cRIO?  Is it flashing?  If so, how many times?
Brandon T.
Message 11 of 18
(1,126 Views)
It is doing a slow, single flash ever few seconds or so.
Message 12 of 18
(1,126 Views)
That means that the device is unconfigured, but we knew that already.  Can you try setting the IP address to be static in MAX, or will it not take that either?
Brandon T.
Message 13 of 18
(1,126 Views)
I just tried that with cross over direct connection. I set it to the right IP, and it still reset to 0.0.0.0
Message 14 of 18
(1,126 Views)
I am having the same problem. Whenever I image it, it switches between error code 60 and error code 1.
Message 15 of 18
(1,126 Views)
My error is 54, not either of those. I cannot Image mine
Message 16 of 18
(1,126 Views)
Called NI, seems that the error is either a firewall or low battery.
Message 17 of 18
(1,126 Views)
I called as well, and got an RMA
Message 18 of 18
(1,126 Views)
