FIRST Robotics Competition Discussions
Using the CAN Jaguar vi s
Is there a reference or help manual available describing how to use the CAN Jaguar vis?  In particular I would like to know how to use the jaguars in postion mode.
I am looking at the vis in the WPI Robotics - Actuators - Motor Control - CAN Jaguar palette and find that while I get context help tips I don't see any extended help text.
Message 1 of 9
(13,519 Views)
Howdy atk!
We are currently working on writing a CAN tutorial for the Jaguars and should have it done soon (hopefully before next week).  When it is finished it will be available here.
-Barron
Barron
Applications Engineering
Message 2 of 9
(7,268 Views)
I am looking forward to seeing it.
thanx;
Arnold
Message 3 of 9
(7,268 Views)
I was just looking for the same information. (We are hoping to use them in the speed mode.) Thank you--I look forward to the tutorial as well!
Message 4 of 9
(7,268 Views)
Any updates on the ETA ?
Z-YA;
Arnold
Message 5 of 9
(7,268 Views)
The document has been posted.
Message 6 of 9
(7,268 Views)
Follow on question -
Can a mix of CAN and PWM controled Jaguars be used at the same time?
Thanx;
Arnold
Message 7 of 9
(7,268 Views)
Hi Arnold,
This question can be read two different ways so I will try to answer both
- You can have some jaguars cintrolled by can and other controlled by pwm.
- You can also use CAN to access some of the monitoring features of the Jaguar will it is controlled over PWM, but this is prohibited by the FRC Rules.
Joe Daily
may the G be with you ....
Message 8 of 9
(7,268 Views)
To follow up on the [FRC 2011] CAN Getting Started tutorial, the [FRC 2011] LabVIEW CAN Jaguar API Introduction and [FRC 2011] LabVIEW CAN Jaguar Sample Use Cases tutorials have also been posted.
Andy H.
Message 9 of 9
(7,268 Views)
