FIRST Robotics Competition Discussions
What is best way to do pulse measurement?
I'd like to measure the RPM of a shooter wheel.  What LabVIEW construct will give me the best timing?
I'm using a simple tacho output from the motor shaft, so no fancy encoders here.
I expect about 100Hz pulses and I'd like to measure at 1% accuracy if possible.
Pulse counting is out because I want to respond quickly to speed changes.
Does the FPGA support pulse measurement?
Phil.
Get a life? This IS my life!
(4,505 Views)
Hi Phil,
The counter in the FPGA will do this for you.  It will also compute rate for you based on inter-edge timing.  Simply configure the counter for Up/Down counter mode and specify your channel. You don't have to specify both.  If you just have a simple tach, you only need to configure the Up channel.  The rest of the rate configuration is the same as Quadrature encoders.
-Joe
(3,337 Views)
Looks like a good solution.
Phil
(3,337 Views)
