FIRST Robotics Competition Discussions
Wind River not authorizing Workbench license on install
Looking for help from NI/WR/FRC.  Wind River installation gives a "license autorization code you entered is invalid" error when securing the temporary activation .  Code is as pre-populated from install disk.
WR licensing directed me to NI.  NI resources/help department for FRC is not currently staffed and suggested that I post here.
Is it possible that WR has stopped activating new software installs?
(9,346 Views)
Hi Matt
I am not sure if Windriver has closed down their activation servers, but this sounds like the regular Windriver licensing error that used to occur on machines that had the same name as one already licensed or containing spaces in the name. Try the documentation listed below and let me know if this resolves the issue.
Windriver LAC
http://decibel.ni.com/content/docs/DOC-3213
Thank You
Eric Reid
Thank You
Eric Reid
Motion R&D
(3,948 Views)
Thank you Eric.  Yourr solution was right on targat!  I guess 'Matt" was not a very unique computer name.
Up and running with updates.  FYI, the 3.1 update links have been repaired if anyone needs to download it.
Sorry for missing the January blog post explaining the solution.
Matt (the unique one)
(3,948 Views)
Hi Matt
Great to hear! Good luck in post season events!
Thank You
Eric Reid
Thank You
Eric Reid
Motion R&D
(3,948 Views)
