FIRST Robotics Competition Discussions
cRio Building Drop Picture
Could someone please direct me to the picture of the person throwing off a cRio from a building. I have seen the video, but it is very hard to obtain a good picture from it. I know there was a picture of it included in the cRio announcement video, so I'm pretty sure that there's one out there.
Also, I was wondering what the name Compact Rio means? What's the story behind the name?
Thank you very much for any help!
(11,111 Views)
Check out the attached pictures - five from the drop and cRIO sky diving, getting run over by a Hummer H2 and acting as a motorcycle ECU.
Compact = refers to the size and ruggedness of the platform
RIO = Reconfigurable Input/Output - referring to the onboard FPGA and variety of I/O modules
Becky Linton
Field Engineer - Michigan
(4,440 Views)
Thanks so much, that's even more than enough good material that I could use.
Problem is, though, that the attachment won't open or save. I get a web page that displays an error, plus next to the attachment it says it's 0 bytes.
(4,440 Views)
I'll try again with the attachment...
Becky Linton
(4,440 Views)
Yep, that time it worked.
Thanks, those are great.
(4,440 Views)
