FIRST Robotics Competition Discussions
can't deploy from new computer
We've created a good program using LabVIEW, and it has been deployed and tested from one of our (Vista) laptops.  We also have an XP laptop.  Both computers have update 3, and our cRIO has been re-imaged for update 3 (from the Vista platform),  but when we copied the Robot Main project from the Vista to the XP, it doesn't deploy from the XP.  The Vista still works, but we won't be able to take it to the competition, so we need the XP to work.  The error message we get when deploying from the XP is something like "FPGA Version not recognized, version should be 2009 and revision should be 1".  Both the XP and Vista were originally installed from the disks provided with the KOP, and both computers were updated using the online updates.  What do we need to do to get the program to work from the XP platform?
mr.e
(5,650 Views)
Hello Mr. E,
Is the issue you are seeing similar to this issue: http://decibel.ni.com/content/message/3749#3749
I believe this was solved by creating a new Robot Project and copying the VIs that you created into that new project.  Can you try this to see if it fixes the issue?  Please here if you still have questions after implementing this solution.
Thanks!
Thanks!
Bob H
(2,833 Views)
