FIRST Robotics Competition Discussions
how to import text and picture from ini file
Hi all,
i am reading one ini file which contents only texts and i am able to read it properly. Now i want to insert some pictires like circuit diagrams in this file and same things i want to read from the file and want to display on my front pannel of program. is it posiible?
regards
manasi
(6,923 Views)
This is certainly possible, you would need to read in the data from the image in LabVIEW and then write the binary data to your file, and then do the same in reverse.
Note that this forum is targeted for FIRST Robotics Competition teams using a customized version of LabVIEW. General LabVIEW questions like this will generally elicit more responses on our main LabVIEW forum: http://forums.ni.com/ni/board?board.id=170
Jeremy_B
Jeremy_B
(3,046 Views)
