FIRST Robotics Competition Discussions
missing file in project creation
Ok thanks for the clarification Joe. I was starting to get mixed up between the two setups. It would be helpful to get a MAX technical report (metioned in the other post) for this system as well.
Kevin Fort
Principal Software Engineer
NI
Message 11 of 22
(1,993 Views)
OK, I will...but if you have any suggestions to try, please let me know. I'm currently re-installing with virus protection turned off per ScienceWhiz in comment 6. I'll try anything for now.
"Lockheed" Joe
Testing Blog"
Message 12 of 22
(1,993 Views)
The lastest error I'm seeing is when I create a new project is:
Error 1055 occurred at Property Node in FRC Create Project.vi->FRC Wizard - Robot.vi
Possible reasons:
LabVIEW: Object reference is invalid
And I still get the Warning on the RT CompactRio in the project with no files listed
"Lockheed" Joe
Testing Blog"
Message 13 of 22
(1,993 Views)
Hey Joe,
I am not sure what may be causing this but we may be able to figure out what is going on from the MAX Technical Report. If you post that I can take a look at it tomorrow.
Kevin Fort
NI
Message 14 of 22
(1,993 Views)
I ran the MAX technical report, how do I post it?
"Lockheed" Joe
Testing Blog"
Message 15 of 22
(1,993 Views)
If you use the advanced editor, you can attach a file.
Message 16 of 22
(1,993 Views)
Since there's a warning on the RT cRio part of the project, it won't let me add anything to that part. I need to get it to deal with the cRio before I can add anything to it.
"Lockheed" Joe
Testing Blog"
Message 17 of 22
(1,993 Views)
Hey Joe,
The create report tool should make a folder which you can zip up and attach to this thread using the advanced editor (upper right of the forum post).
Kevin Fort
NI
Message 18 of 22
(1,993 Views)
I finially got back to this. When I started MAX I got a known exception becasue of PAE (Physical Address Extension). I dug down and the ways microsoft said to turn it off didn't work.
Anyway, I went to MAX and here's the report
"Lockheed" Joe
Testing Blog"
Message 19 of 22
(1,993 Views)
Hey Joe,
Did you see this KB: http://digital.ni.com/public.nsf/allkb/8355753BD0C8E62F8625768C005B359B?OpenDocument. Not sure if these are the methods you already tried but I suspect that this issue is what is causing our issues with using this computer.
Kevin Fort
NI
Message 20 of 22
(1,993 Views)
