FIRST Robotics Competition Discussions
other joystick axis
I understand that Axis 1, 2, and 3 is forward/back, left/right, and rotate right/rotate left.
What does Axis 4, 5, and 6 do?
Davis Catherman
(6,989 Views)
Nothing, unless you have a joystick with 4, 5, or 6 axes like this one: http://www.bestbuy.com/site/Cyborg+-+X+Flight+Stick/9388824.p?id=1218096957779&skuId=9388824&st=joys...
(3,716 Views)
I believe axis 4 is the throttle on the Logitech joysticks (the rotating dial at the middle-rear of the joystick base).
(3,716 Views)
I looked into it more,
For the Attack 3 Joysticks:
Axis 6 - nothing
axis 5 - nothing
axis 4 - nothing
axis 3 - dial at base of joysstick axis
axis 2 - y axis
axis 1 - x axis
For the Cyborg X Joystick:
Axis 6 - left/right on thumb axis
axis 5 - right throttle axis
axis 4 - rotation axis
axis 3 - left throttle axis
axis 2 - y axis
axis 1 - x axis
So I don't know how to get up/down on thumb axis.
Davis Catherman
(3,716 Views)
Check the button status - the thumb axis may be reported simply as either button pressed or not pressed, rather than showing a variable amount of pressure.
(3,716 Views)
