FIRST Robotics Competition Discussions
"Conflict Resolution"?
After downloading the update, I can no longer get the Robot Code loaded.  Here's what happens:
I select "connect" for the RT, no problems.
I select "Build" on the RT and get a "Name collision" dialog come up--a bunch of VIs are renamed and saved somewhere else because they conflict with existing files.
I select "Run as startup", no problems.
I click on RobotMain.vi, hit the run button, it starts to load and then eventually I get the following dialog:
     Conflict Resolution
               HandleRunTimeErrors.vi
               AutonomousIndep.vi
               AcquireImage.vi
               SendImages.vi
               RobotMain.vi
               AsymVIAgent.vi                         These files can't be found so the program can't run...
Ok, so what do I need to do to get my Robot Code loaded?
(3,986 Views)
Reading other, unrelated posts gave us the idea of re-imaging the cRIO.  (One of those "what the heck, let's give it a try" type of things).  It worked--our robot code loaded and we are now driving our robot with wild, reckless abandon...
(2,891 Views)
