FIRST Robotics Competition Discussions
two solenoids and one relay
I am trying to  be able to control two solenoids with the one relay on the cRio.  I Can get one at a time but not both working.
I believe i have programmed it correctly,  i have checked out the wiring ,etc i know that the solenoids work and the wiring is good.
i think i must have a mess up in the begin file maybe
any help would be great   thanks
(3,775 Views)
It would be much easier to help if you posted your code and described your wiring. With the information you provided, all anyone can do is to guess what the problem might be.
(2,887 Views)
ok thanks will do
(2,887 Views)
