FIRST Robotics Competition Discussions
we can't get labview 2011 to imag to the crio.
when we imag to the crio we don't get a error message. but the joysticks are slow to responed and the drive moters will start and stop on there own. it does work with 2010. we have installed all updates for 2011 with no errors. help?
(4,219 Views)
Hi donrfe,
Are you using the basic code templates or have you made any modifications to the code? If you have made modifications, can you post the code?
Also, did you apply the new image to the Classmate or just update LabVIEW?
Did the code deployment proceed without errors?
Thanks!
Tanya V
Tanya Visser
LabVIEW Group Manager
(3,264 Views)
hi tanya
we get no errors. the code works with 2010!
thanks don
(3,264 Views)
Hi Don,
Are you using one of the examples? It's possible that some of the VIs are not being updated often enough. This year, safety configuration VIs are used instead of the Watchdog VIs. If the loop rate is too slow for the motor control, it is possible that your motors would periodically stop.
Could you post your code and let me know if it is example code or custom code?
Tanya V
Tanya Visser
(3,264 Views)
