FIRST Tech Challenge Discussions
Code Generation Button is Missing
When I open the remote control editor, the code generation button is missing. Last year it was right after the save and close button on the top of the window. What do I need to do to get the button back?
(7,939 Views)
That means you have LabVIEW for Lego Mindstorms, but you don't have the FTC Toolkit installed. You can download it from here:
https://forums.ni.com/t5/FIRST-Tech-Challenge-Documents/LabVIEW-Software-Setup-for-FIRST-Tech-Challe...
In addition to that button, it will also give you access to the autonomous templates and examples.
Tony
(3,542 Views)
Thanks a bunch. I knew it must be something simple.
(3,542 Views)
