FIRST Tech Challenge Discussions
FTC controller buttons mapping to read button VI in FTC toolkit? (Archived)
Update: This discussion applies to Issues from the 2010 FTC season and is no longer relevant for current FTC competition software.
Is there a reference document that maps the FTC
controller buttons to the buttons on
Read Buttons VI from FTC toolkit?
(4,327 Views)
There is no document for this.  The reason we didn't create such a document is different game pads and joysticks will map their buttons differently.  This being said you can make your own document for you team.  Plug in your joystick and open the FTC Controller Station and copy down which buttons light up as you press different buttons on the controller.  Granted this doesn't let you map every single available button output from the Read Buttons VI (not all 12 are shown in the FTC Controller Station).  To do this you will have to write a simple test VI to see what outputs correspond to each button on your game pad or joystick.
Mark
NI App Software R&D
(3,334 Views)
