FIRST Tech Challenge Discussions
Help! How to program a motor to turn in certain degrees?
i. we are trying to program a 6th moter to turn only 30 degrees, then turn back to its original position. We have never used a button on the joystick to do this. Can anyone give us the full code for this?
(6,939 Views)
Can you explain a bit more about what you are trying to do?  I presume you mean a DC motor and you are looking to turn it X degrees (90, 180) etc.  If so, why are you using a DC motor instead of a servo?  DC motors are not really intended to reliably move a certian numebr of degrees.
(6,016 Views)
If you are using a DC Motor, you could get some pretty good results using an attached encoder.  There's an encoder tutorial here:
https://decibel.ni.com/content/community/academic/student_competitions/frc/blog/2015/01/16/encoder-f...
Otherwise, I agree with Eddie that a servo would work better in this case as servos are designed to move to precise positions.  A stepper motor might serve well too.  You could figure out how many steps it took to move 30 degrees and hard-code that number.
-Jim B
Applications Engineer, National Instruments
CLD, CTD
(6,016 Views)
