FIRST Tech Challenge Discussions
I can't generate code in the remote control editor.
In the remote control editor there is no option to generate code. This is for an FTC team. Also There is also no telop mode. If anyone has had this problem how would I fix it. I am using Lab View 2012.
(6,571 Views)
Accepted by topic author TristanWard
In order to get the code generation button you need to install the LabVIEW toolkit for MINDSTORMS competition. Once you install it you should be good to go.
Cheers
Hunter
(4,014 Views)
