FIRST Tech Challenge Discussions
OnBoardFiles directory .rxes concerns
The NXTShell, samostat, and Program Chooser .rxes are being pulled in from the directory [ C:\Program Files (x86)\National Instruments\LabVIEW 2012\vi.lib\NXT\Subs\OnBoardFiles ]  when you first run the NXT in direct mode. These .rxes are provided by NI and were compiled on 10//25/13.
We  all are experiencing issues with Program Chooser and the FCS ( https://decibel.ni.com/content/thread/19513?tstart=0 ). I am now concerned about the samostat behavior.
The compile size for a new deploy of the 'Program Chooser.vi' is 5.31 KB, quite different than the one in the \OnBoardFiles directory which is 3.32 KB.
I did a fresh comple for the samostat.vi from the directory [ C:\Program Files (x86)\Samantha Field Control System\Labview ] and the file size was 5.9kb versus the one in the \OnBoard Files directory which is 2.14kb.
Has anyone had issues with a non-working samsostat program?
If these 2 vi's are not up to date, then what is the status of the NXTShell?
Thank You.
(3,524 Views)
We were just at a 10 team qualifier with 8/10 teams using LabVIEW. The Program Chooser/NXT Shell/samostat from the 'direct target' download all worked fine.
We've also experimented with changing the file in 'Program Chooser' and didn't see any issues. I do have the students back out to the 'software files' menu after running 'Program Chooser' on the NXT.
Not sure that the samostat was ever employed.
(3,330 Views)
