FIRST Tech Challenge Discussions
Run teleop program through FCS
We have trouble with running the teleop programs in the control of  FCS. We ran Program Chooser and selected teleop program on the NXT, it showed "Error saving Config file". We cannot run the teleop program when autonomous period ended and "continue" button in FCS was pressed. Please advise on this. We appreciate your help.
(4,705 Views)
I've not seen this, but I'd suggest some things to try.
1) Maybe your NXT is full, or badly fragmented.
     Use Labview's NXT Terminal, to delete any files you don't need and then select the "Defragment" button.
2) Maybe an old verion of the FTCconfig.txt files exists but is corrupted.
If all else fails, reload the NXT's firmware.  This will erase the memory, and clear out the file system.  You'll need to relaod the program chooser and your teleop program.
Get a life? This IS my life!
(3,442 Views)
Thanks a lot! It worked out yesterday miraculously.
Esther
(3,442 Views)
