FOUNDATION Fieldbus
Accessing the NMIB
Is there a way to view the Network Management Information Base (NMIB) data in a device using NI Configurator or NI Dialog?
(7,008 Views)
Right click the interface icon on left part of Configurator, select "Advanced View", all the parameters will be listed under each device.
If you know the parameter name, then you can access it in NI Dialog.
Feilian (Vince) Shen
(6,994 Views)
Yes, that shows the MIB data and other user defined blocks, but not NMIB data.
(6,992 Views)
