FOUNDATION Fieldbus
Add ethernet interface using NI-FBUS interface configurator
I am using NI-FBUS Configurator version 3.1.
When I use the Interface Configurator Utility 3.1 to add an ethernet interface, I receive the following message:  "HSE functions are not supported. Ask fieldbus.support@ni.com for more information."
Anyone have any suggestions?
Keith
(7,186 Views)
Keith,
Your Configurator doesn't support HSE features, and you need to order Configurator for HSE version if you want to use HSE features. Another option for you is that you can order NI-FBUS CM for HSE (778541-01), which could enable the HSE features for your standard Configurator.
Hope it helps.
(7,168 Views)
