FOUNDATION Fieldbus
Applications running error
I just purchased a FFB USB modem, and when I try to run Comm. Manager, I get the error " One of the applications is running ( Communications manager, interface configuration utility, add interface wizard)  Communication Manager cannot run unless you close the above application."  When I check the task manager, no NI programs are running.  How can I get your product to run?
(7,214 Views)
Here you need to check whether you have run one of the three:
1. Communications Manager
2. Interface Configuration Utility (Start Menu -> All Programs -> National Instruments -> NI-FBUS -> Utilities -> ...)
3. Add interface Wizard
Thanks.
-Chris
(7,211 Views)
I can't run any of them, I get the same error message as stated in my first post
(7,207 Views)
Hi, would you please email to fieldbus.support@ni.com for further support?
Thanks.
(7,200 Views)
