FOUNDATION Fieldbus
BKCAL_IN/BKCAL_OUT in cascate loops
When I am using two cascate PID loops (OUTPUT of the outer PID connected in CAS_IN of inner PID), frequently, the inner loop reaches your maximum value,
but the outer loop go on increasing its output (a windup effect). It seems that it´s possible to
overcome this using the BKCAL pins. If it´s true, How must be the configuration of PID blocks?
(7,716 Views)
You can use NI-FBUS Configurator to save your FBPA configuration in FCP format, and send the FCP file
or your PID configuration diagram to fieldbus.support@ni.com for further support.
BTW: What kind of PID function block are you using in your configuration settings?
(7,716 Views)
