FOUNDATION Fieldbus
Can we connect more than two devices using the NIFBUS Dialog utility?
I am not able to connect more than two device with visitor address on the same link using the NI-FBUS dialog utility. I am just trying to understand if it is a limitation of the utility? Can somebody help me on this?
(7,113 Views)
Could you please tell me which version you used?
The dialog doesn't have any limitation for the device to open. Please refer to the attached screen shots for version 4.1.
Some screen shots with problem from you would be helpful to solve the problem.
BTW, use Expand All to open all the links and devices.
-Chris
(7,112 Views)
can we connect more than 4 devices with all the devices having a visitor address on the same link?
-Sundar
(7,105 Views)
Hi Sundar,
Yes. I just used 3 devices as an example.
The Dialog doesn't have any limitation of the FF devices for the link.
Could you please tell me what error you met when using Dialog?
Thanks.
-Chris
(7,100 Views)
