FOUNDATION Fieldbus
Device_id about FF device
Dear vince:
        thanks for your reply about the fail error,may be there are some problem in my dd file.besides I also have a issue with Device_id about FF device ,because Device_id  is unique,and could't be Modified in the NI configurae software. Device_id in the firmware is same when we flashed in batch,so could you provide a method to Modify the Device_id parameter in the NI configurae software, then there is no conflict in the second FF device in the network when the first FF device is online whose Device_id  is Modified.
        thank you very much!
        Bob peng.
(7,258 Views)
Dear Bob,
Device ID can not be modified using Configurator because it is a parameter that is not writable.
The steps to view Device ID in Configurator are:
- In Configurator device list tree window, right click and select Advanced View.
- A MIB block icon appears under device icon. Expand MIB block.
- Parameter DEV_ID is listed under MIB block.
Parameter DEV_ID is read only, so Configurator can not modify its values.
Feilian (Vince) Shen
(7,240 Views)
