FOUNDATION Fieldbus
ERRORDSNF on all resource blocks in NI-FBUS 3.1.1.
Does anyone have experience with the ERRORDSNF on all of the resource blocks on a network?
I'm trying to connect a new device to an existing network, but it won't let me download
I'm new to Foundation Fieldbus and we have NI-FBUS 3.1.1 with Allen-Bradley 1788-CN2FF linking devices.
The values in the PLC program are changing, so I know that the devices on the network are communicating.
(8,149 Views)
Accepted by topic author GCobb
Hi GCobb,
Edit:
Please refer to the post here first.
And try these latest files in the attachment of this post.
Only the new device you plugged into the network has such issue, or all the devices have such issue when the new device is connected? I mean if you can narrow down which device caused this problem and seperate it and then check what went wrong with the device, or PLC programming or anything.
Regarding diagnosing, the diagnose tab in a block helps.
Regarding error message, the fcs.pdf that comes along the installation of NI-FBUS has a chapter called Error Messages and Warnings that explains NI-FBUS Configurator error messages.
Thanks.
(8,145 Views)
