FOUNDATION Fieldbus
FBUS Communication 3.1 manager crashes with AT card
I have version 3.1 of the communications manager which works fine with an application that is written which uses the old NI-FBUS API (the C functions).  On a different appliction which is coded up in a new application which uses the new NI-API (.NET code) the FBUS communications manager 3.1 crashes.  I have an AT FBUS card and wonder if that is a source of the problem.   That being that verions 3.1 of the FBUS Communications manager it is not compatible with an AT card.  I thought someone told me they "figured out a way" to get the communications manager version 3.1 to work on the old AT card???  So question #1 is an AT card compatbile with FBUS communication manager 3.1?
When FBUS communications manager crashes it is very random and doesn't seem tied to a device under test.  It happens sometime when doing reads, sometimes when doing write....there does not seem to be a specific point or location that it fails.  Again some times it runs fine for a long time and then fails other times it fails almost right away.  I have to restart the communications manager to get it to work again and reconnect a device.  Again my old program that uses the old NI FBUS API works great on the same card with FBUS Communications manager 3.1.
(6,728 Views)
AT-FBUS is compatible with CM 3.1.
Have you tried the .NET examples which are installed with NI-FBUS?
Ryan Shi
(6,719 Views)
